4
10-22 Split receiver
3
Like what you see?
10
682bear
Active Member
Active Member
Nov 28, 2016
76
Likes
118
#3
I machined a 10-22 receiver from an aluminum block several years ago... I added a second action screw behind the trigger assembly and threaded the front for a screw in heavy barrel. I then installed a 1 inch diameter Anschutz barrel, and put it in a target style stock. It shoots good, and is very accurate.
-Bear
JerryK
Active Member
Active Member
Nov 9, 2017
41
Likes
77
#5
-Bear
No testing yet, but I could use a bull barrel
682bear
Active Member
Active Member
Nov 28, 2016
76
Likes
118
#6
I also left the top of the receiver something like 1/4 inch thicker (I can't remember exactly) to make the receiver more rigid. I machined it to look similar to a coffin lid.
The barrel was one of a lot of Anschutz 'test barrels' that Numrich had acquired and were selling for @ $55.00 if I remember correctly.
They were oversize and had features machined in them to mount them in a testing jig of some sort... I cut it off to 20 inches and turned it down to 1 inch, and turned and threaded the tenon to 3/4 inch.
-Bear
derf
Active Member
Active Member
Oct 3, 2015
345
Likes
292
#9
They haven't made the 10/22 magnums for about 15 yrs. The thing about the magnums is that the breech block was made from solid tungsten and weighed 15 oz, where the standard 10/22 breech block weighs 5 oz.
magu
Active Member
Active Member
Jun 6, 2014
74
Likes
37
#11
Looks good, are you finishing it as a charger? Out of curiosity, why did you build it in 2 halves?
MontanaAardvark
H-M Supporter - Premium Member
H-M Supporter-Premium Member
Jan 3, 2015
253
Likes
97
#12
That's very cool! I never thought of making a 10/22 receiver split down the middle.
I've been going back and forth on making a 10/22 from scratch just as a "Tack driver". With companies like Tactical Solutions, it's rough to decide if I can make one as good or better. Of course, the answer there might be "make it and see".
Bob
Hozzie
Sep 8, 2016
121
Likes
78
#13
I would recommend you look for a smaller diameter barrel. Less weight to support and they are easier to tune. Something in the .800 or .850 diameter.
JerryK
Active Member
Active Member
Nov 9, 2017
41
Likes
77
#14
The barrel can changed, to abide different state laws.
I made the split receiver just to do something different
Take care
Jerry
JerryK
Active Member
Active Member
Nov 9, 2017
41
Likes
77
#15
Bob
This was a prototype. I just wanted to make sure of the fit
and all dimensions correct on the inside.
Once that was accomplished , the outside can have many variations.
It’s only a hobby
Jerry
6
5 7
