I also. KF4ZHT, it appears that you may have accidentally hit the POST button before you were finished writing. The little bit of text in between your two photos doesn't make any sense as is. You may not have known that at the time you were entering your thread, all that you had to do was to click on the Edit button and go ahead and finish what you were writing. As more than 24 hours have elapsed, you can't edit the post. Probably the best thing to do would be for me to simply delete the thread and for you to start over. Let me know.
