- Dec 9, 2016
- 1,133
To the Op would you mind sending me a copy of that drawing you got from Clausing please? I have 3 missing teeth that are exactly 1/3 of the gear away from each other (the 3 missing teeth form a perfect equilateral triangle if you were to draw a straight line from one to the other across the gear face) ive kicked around with brazing on some brass and cutting the new teeth but so far the 3 missing teeth have not adversely effected my lathes work ability but i know there will be a time i will need that info and well why wait until after it goes down to collect the materials needed.
