Shopping for a Shop
I built mine to county rules then added on bill
Check for storage or other clever names as permit fees and restrictions are different.
Then also look for buildings that are big that should not be...
Our county has the 15 ft setback and height limits as well.
Shop is 2 level and 24 ft tall...NOT allowed but...
In our many trips to the building department we got one person who knew of a special clause...off the books or hidden in the books to allow outside of normal.
Was explained that some "special person" needed to build so they created a process and once in place had to stay in place.
Was told my permit would be stalled but to make note of where rule filed to point it out....
So there may be special circumstance that may allow a larger building to be built if certian hoops are found to jump through.
We are on 1 acre and shop is 30. X 60 X 24 tall.
There was someone on garagejournal.com who got around height codes by building down so shop mostly under ground. Turned out nice the way it was done
Cadillac,
My issue is not so much height of the building, but the amount of space I want vs what the city will allow.
I have decided to do a ruff sketch and take it to the city planner and ask what they will allow.
toolman_ar
