- Nov 25, 2015
- 8,052
Good to know... Hope you are getting better.
The milk myth helps settle the stomach but it doesn't really do anything to eliminate the hazardous chemicals that's been ingested. Extracting the fumes is always the best.Good to hear that you are improving, Glenn. Years back I used to do a lot of welding on heavy equipment and quickly learned to avoid those fumes.
As for the old trick of drinking milk to avoid getting sick from welding galvanized material, yes, it works, but is no help for the rest of it. Despite that, avoidance is the better option. Similar to the old adage that "an ounce of prevention is worth a pound of cure."
Glenn,Regarding equipment - I haven't yet found a face mask that works with eye glasses under my welding hood. Every one I've ever tried fogs up my glasses within a few seconds, rendering it impossible to see what Iam welding. So I don't use one. Now Iam going to see if I can find a respirator that works with eye glasses. (Open to suggestions)
Glenn
Glenn,
There is a solution, but it's not cheap. 3M makes a powered respirator welding helmet--there's a filtered fan that fits on your waist away from the welding and blows fresh air into the mask. They run about $1300 new. I've seen them onCL for a lot less, but still several hundred bucks. On the plus side the 3M helmet is highly regarded and very light. It can also be used without the welding filter as a dust respirator for woodworking or other dusty activities.
Bob,they make hoods for welding that cover your head a hose comes up the back from a filtered air pump on your belt. the ones we had were Racal great for grinding too. expensive but then what does new lungs cost?
