Squaring Fixture Surface Gauge With Radious Edge
rgray
Nov 26, 2012
1,307
Square checking fixture.
Ebay item #: 182177877834
It can only be used to compare. It needs to be calibrated to verify square. And the base has been sand blasted. And it has an import indicator. I think very over priced.
Used to compare sides. Zero on first side then rotate to next etc. No calibration needed. The bottom has been reground.
