Might give this a try. I've been using open gear lube and it gets all over the place.Stens 770-123 "00" Grease!
I've tried just about everything and this stuff makes my change gears super quiet. The only negative is changing the gears (sticky mess). The color is a semi-clear light blue gray. Much cleaner than the open gear lub.
Amazon has it for 22 a quart. I'm guessing one quart will last me 10+ years
