[How do I?] Some Help On Threads
the backplate may be smaller than the chuck, it does not have to be the same diameter, as long as the register and the boltholes fit it is ok
The bolt holes are front mounting, in the 4 jaw chuck so i could make what you are saying, off course i will need to make another one for the 3 jaw chuck.
How thick the back plate should it be to hold it well?
Here is Tony's response on my e-mail.
Hello Dimitris,
Thank you for your message.
Your "unknown" lathe is of a type made from around 1910 to 1930 (or so...) . Almost all makers of machine-tools at the time produced something similar and, as with yours, it was not uncommon to find a complete absence of any maker's name or insignia. These unbranded machines were often the result of a major dealer or distributor ordering a large quantity on the understanding that no identification was attached - and he would then add his own screwed or riveted-on badge, often in the form of a bronze casting. These elegant badges make tempting souvenirs - looking for tell-tale holes in the bed might give confirm this. Machine tools were often copied and, if your area had a manufacturer of weaving equipment, it's likely that they would be responsible - even a back-geared and screwcutting lathe is nothing as to the complexities of a powered loom and such lathes made a useful fill-in when other sales slackened.
It's not a lathe I've seen before but, from its general appearance I'd guess that it's German in origin - some German companies using Whitworth threads into the early 1900s - and on larger threads for much longer.
Sorry that I can't help further.
Might you have a set of clear pictures showing the whole machine and details that I could include in the Archive?
My best wishes,
Tony.
I will try to take some clear pics, if i manage to find a good camera.
http://www.ebay.de/itm/Grauguss-Dur...sh=item4d3f02c8ce:g:nr8AAOSw9N1Vwkg8#shpCntId
price is for 10mm , shipping to greece 14,90
so 50 mm would be euro 51 plus 14,90 shipping
Thank you very much for searching form me my friend, the price i think is for 190mm but my chuck is 200mm so i need lilte over 200mm.I will search to ebay and perhaps i will find some good deal.
To be honest i did not think of searching to ebay for something that heavy cause i though that the shipping cost's will be high, but 14,90 is very logic price.
I still did not manage to go for searching in shops, i think i will eventual find something.
I've already send him a question if he could send me a 45 mm length off 210mm and I am waiting for reply.
Unfortunately I do not know German and the translators don't work in item description.
Does he have a max 40kg shipping policy?
Edit: He replied and the cost is 49 euro and 29.9 euro shipping costs so I will try to find something near me.
before you start buying anything MEASURE the spindle nose
Today i manage to still some free time away and i decided to follow your suggestion and machined the old back plate.
Because this was my first machining ever i took it veeery slowly and do the lack off lathe tools i just used an index parting tool and made a new reassess to fit my chuck, i ended up with a very tight fit and without any visible play.
Then i transfer the bolt holes from the chuck to the plate, the chuck is a front mount so it was easier.
Then i drill the 8,50 mm holes and when i tried to tap with an M10 tap i could not start it straight so i gave up for today, i just need to make a jig to keep it straight until it starts.
When i finally mout it i will try to make another on for the 3 jaw chuck.
As about the spindle nose i will have to give the old plate to a machinist so he could transfer the hole and the threads to the other stock that i will buy, as i said before in the post my lathe can't thread at the moment.
EDIT: 04/05/2016 I have mounted the 4 jaw chuck and i think everything went well.
Now i need to train my self on centering the work piece!!!
if you measure the spindle nose exactly it is easier to find a backplate
i have some backplates in different sizes i will never use again
if one of them is the right size its yours if you want it
