- Mar 19, 2014
- 2,680
I hear you on the concern for run out on a thread mount chuck. I also have a 5/8” chuck but can’t recall the last time I needed it? But good to have, can’t have enough toys! I have many many chucks in the piles, but I grab my favorite ½” Jacobs 99% of the time. I do not like the keyless chucks. My favorite chuck is not ball bearing either. Just a standard Jacobs. But it holds tooling true and for that reason, I use it and will never let it leave my sight. I would hunt down a chuck that holds tooling true and not be overly concerned about appearance and or other factors. I just realized a threaded chuck could unscrew on you when in use!I had to get it pretty quickly and went over and moved it near the shop door with an engine hoist ...I was going to hire someone to get it from there as the hoist was close to useless and would never get it high enough for the trailer . No takers on the hire so I decided to build a gantry crane . That what you see around the mill in the trailer. It's wide enough to straddle the trailer and ten foot tall. It assembles in about 15 to 20 minutes and I bought a 2 ton chainfall . The whole show was less than $150 and was money well spent. The mill handles are surface rust. the table mostly oil and grease ...It looks better than the photo shows. I cleaned up one side and it looks good but it could go right into service the way it is , but i'll clean it up a little. I have a nice 5/8" jacobs chuck that needs an r8 adapter it's threaded 3/4 16 and I'm wondering if that's a bad idea to use a threaded chuck,probably it is a bad idea! I have other jacobs chucks but they are 1/2 "
