Minor terminology correction - Drawbars are solid, with an external thread, and are used with collets like MT and R8, and with various types of mostly MT shank milling cutter holders. The photos above all show various types of draw tubes, which are hollow and have internal threads. You can probably make a 5C draw tube or you can buy generic ones various places including eBay. Cut to length to fit your spindle and handwheel. When determining required length, SOP is to have between 50% and 75% of the collet threads engaged when the collet is properly closed on a part or gauge that fits it exactly. Too little engagement and the threads may suffer premature failure. Too much engagement and you may bottom the threads before the collet is properly closed slightly undersized part.
