Ball Turner Without A Ball Turner
Did it the same way as a tracer lathe. Good Idea if you need to copy something.
neat perspective with the camera mounted on the tool-post.
makes it look like the balls and ways are moving.....
-brino
Now thats what I'm talking about.The KISS approach. You know what you want and you go for it.
Break it down to the simplest steps and just do it.
Anyone know what language he is speaking?
***G***
From the text, most likely Russian.
that's clever, could use that to quickly copy so many things, thanks for sharing
I had to make a bearing cap once that had the outer race built into it. I used the same approach. It worked great. I used an indicator on my tracer part.
