4-jaw Indepedent Chucks
Jeff/Tools4cheap is OOS on the 6" 4-jaw and is moving so no ETA. I've been looking around and it seems only 8" or larger 4-jaw chucks come with 2-piece jaws. I'm really interested in a Gator 6.25" 4-jaw but it comes with solid jaws.... like everything else in the 6" range. Is there a reason for this?
There is really no reason to have 2 piece jaws on a 4-jaw chuck unless you want to install soft-jaws, the jaws are reversible anyway . Making them with solid jaws is a bit cheaper than the extra work of making 2-piece jaws, also it makes a bit more compact chuck because the jaws won't stick out as far.
Got it. Thank you Jim. Knowing that should make things easier for me to decide what chuck to get now..... may just go with the Gator.
I put the biggest 4 jaw that will fit & I can afford. I was going to get a bigger chuck for my last lathe but the "can afford" part stopped me. Don't forget about the jaws sticking out when sizing.
